1993 Honda Prelude oil leak
1993 HONDA PRELUDE
222,000 MILES • 4 CYL • 2WD • MANUAL
MGRWC14
Hi!
I have a Honda prelude 1993 with 222000k. I just recently got an oil leak... The oil leak only happens when the car is on.. other wise no oil leaks? Do you know how or whats causing it? I checked the seal and that seemed to be fine.
Jul 9, 2008 at 4:49 PM
2CARPRO JACK
  • 11,533 POSTS
Check around the oil filter and the oil pressure sender. Try cleaning it off with carb or brake cleaner then run it to see where it is coming from
Jul 10, 2008 at 12:51 AM
