1993 Honda Prelude no compression
1993 HONDA PRELUDE
IMPORTPRINCEZZ
  • 6 POSTS
Engine Mechanical problem
1993 Honda Prelude 4 cyl Front Wheel Drive Manual
I have a honda prelude that i'm trying to get running. all cylinders but number 3 have compression. not sure why this could be. any suggestions?
[img:79eff45992]http://www.2carpros.com/forum/automotive_pictures/170179_LUDE1_1.jpg[/img:79eff45992]
Jun 12, 2008 at 4:26 PM
  • 31,937 POSTS
Hi there,
do a wet & dry compression test. dry test is just a normal comp test, and note the reading. Then squirt some engine oil into the cylinder, not a lot just enough to coat the top ring, do a comp test again, if the readings go up it will be faulty rings if there is no real improvement you have a valve issue.
mark (mhpautos)
Jun 12, 2008 at 6:34 PM
