1993 Honda Prelude just stumped?
1993 HONDA PRELUDE
BMXER686DRIFTER
Engine Mechanical problem
1993 Honda Prelude 4 cyl Front Wheel Drive Manual
i got a 93 prelude si and i cant figure out what is wrong, i got it to work three months ago just fine. the batterie is good the alternator is fine. it just wont turn over. and there also a hole under my distributor cap that leaks out radiator fluid. can anyone help me?
Sep 29, 2009 at 4:26 AM
KHLOW2008
  • 41,814 POSTS
Hi bmxer686drifter,
Check out this link for what to tst when you are not able to start.
https://www.2carpros.com/kpages/first_things.htm
The coo;lant leakage should be due to a cracked heater hose under the distributor. A visual inspection would be able to confirm this.
Oct 2, 2009 at 4:14 AM
