1993 Honda Prelude CPS
142,000 MILES • 4 CYL • 2WD • MANUAL
PRINCEJAA
Hi. i recently bought a 93 honda prelude. and its giving me a hard time. the car normally starts fine. but sometimes early morning, or the engine is driven for some time, if i was to start it, it would jus crank and not start. and if it does start, it would eventualy die to 0 rev/ min. i thought it was the cps ( camshaft postion sensor) but im not sure if that is the problem or not. please reply back to princejaa@hotmail.com thank you.
Jun 9, 2009 at 11:25 AM
KHLOW2008
  • 41,812 POSTS
Hi princejaa,
When it could not start, you need to check what is missing. The following link has info that can help you. Check through them and see what is missing when it could not start and if you require additional assistance, reply to this post and I will get back to you when I am online.
https://www.2carpros.com/kpages/first_things.htm
One of the most common failure for the symptoms described is the PGM-FI main relay. Removing the relay and resoldering the circuit board usually solves the problem.
Jun 13, 2009 at 8:20 PM
