1992 Honda Prelude timming
1992 HONDA PRELUDE
KBDOGS214
Engine Performance problem
1992 Honda Prelude 4 cyl Front Wheel Drive Automatic
i have a honda, h23a1 4 cyl, duel overhead cam, and i am having trouble getting the timming down after replacing all vaccume lines, and valves, timming all the ballancers, crank, cams, and even with the distributor turning, i cant seem to get the idol timming to its proper 850 rps's on a cold start idol.
Feb 25, 2009 at 4:51 AM
KHLOW2008
  • 41,814 POSTS
Hi kbdogs214,
During cold start, the idling speed usually starts at about 1500 and when warmed up it goes down to 700 rpm.
Can you provide a clearer description of the problem you are having?
Feb 25, 2009 at 5:19 AM
TED-E-DEE
  • 109 POSTS
Honda Dual -Cams, when you set your cam timing, did you know there are holes in the cam shafts ? Just b-hind the cam pulleys, in the first cam cap, there are holes that you can put a punch in each one to hold cams in place. You want to use a punch as close to the size of the hole as you can. i do not remember what size they are, but you will figure it out after you try a couple. If you have any vibration when your done, in the motor, that useually means the balance shaft belt may be off a tooth or two. Good Luck if your not done w/ it already.
Apr 22, 2009 at 1:12 PM
