1992 Honda Prelude Tail Lights, Fog Lights, and Guage Light
178,000 MILES • 4 CYL • FWD • MANUAL
TFLO19
I was racing a car and going about 140 and my fog lights tail lights and guage lights all went out at one. I checked all fuses and wires with test light, all fuses were hot, only headlight wire was hot coming out of the fuse panel. all fuses and relays good in the under hood fuse box. replaced light switch and that was not the problem. I dont know what the problem is.
Feb 28, 2009 at 11:43 AM
KHLOW2008
  • 41,812 POSTS
Hi tflo19, Thank you for the donation. All the lights mentioned gets its power from Fuse # 42 in underhood fuse box.
https://images.2carpros.com/forum/automotive_pictures/192750_FuseBoxHood92Prelude_1.jpg
At combination switch, test for power supply to Red/Green wire with lights OFF. Power must be available at Red/Black with switch turned ON. Let me know what you find.
Mar 3, 2009 at 2:51 AM
TFLO19
i found the #42 fuse was empty, i remember pulling #42 on the night all of it happend. It was blown. I just tried replacing it and every fuse i put in was blown immidiately (3 fuses). by combination switch do you mean light switch?
Mar 3, 2009 at 7:48 AM
KHLOW2008
  • 41,812 POSTS
Yes, I meant the light switch.
If the fuse blows immediately once the switch is turned on, there is a shorting somewhere. It could be a bare wire, maybe due to abrasion or some external impact.
This is not going to be easy unless you have any damage area which you can check first.
Try unplugging the wireharness to rear from fuse box to test and isolate it fron front.
Mar 3, 2009 at 11:13 PM
TFLO19
fixed, it was the two bumper lights mounted on the side of the rear bumper, they were broken and corroded, i just clipped the wires, covered them and wallah, got my tail lights, fog lights and guage lights back. thank you for all your help!
Mar 7, 2009 at 6:38 AM
KHLOW2008
  • 41,812 POSTS
You are welcomed and glad that we have been of service.
Feel free to drop by if you have any other questions.
Have a nice day.
Mar 7, 2009 at 2:28 PM
