1992 Honda Prelude starter
1992 HONDA PRELUDE
100,000 MILES • 4 CYL • FWD • MANUAL
PATFLA
bought it used. hhad a short in the ign, switch but fix it. the car will not cranck over. I get a loud snap at the starter. i jump the neutral safety switch. i changed the starter.battery is new. iwas able to roll the car in gear for 2 ft and tried to start it and it work(with the key) now i'm back at square 1 with the loud snap the whole car electrical shuts down for about 2 min. this car had an engine swap . it now has an H22 engine the of it ?????. could the starter be the wrong one. i matched them up side by side and counted teeth.. please help my son is making me crazy
Jul 26, 2010 at 7:03 AM
KHLOW2008
  • 41,814 POSTS
Hi patfla,
If the electricals are going off, check the battery terminal and ground circuit connections.
Does the starter cranks if you use a remote wire from the starter solenoid?
Aug 1, 2010 at 2:45 AM
