I scan my car using the obd code reader and it says code 12 (no EGR action). Whats happening in my car is even if i step on the gas it is just reving up but not speeding as much as i wanted to. I asked my mechanic and he says there could be a vacuum leak, transmission problem or timing belt wasnt put on properly or the egr valve as well.. I havent replace the fuel filter since i bought it about 4 months ago, would it help if i replace that too? i already replace the wire set, plugs, air filter... Help anyone???
Mar 27, 2009 at 1:14 PM
