1992 Honda Prelude Batter light pops up
SLIK6691
Electrical problem
1992 Honda Prelude 4 cyl Front Wheel Drive Manual 139k miles
I have a 92 honda prelude SI, i just got it almost a month ago and its been giving me problems here and there. My belt broke for the ac compressor/alternator and i had to get a used ac compressor and a new belt. But the belt fell off and broke again yesterday. My power steering belt( i think thats what it is) broke as well but only on the right hand side as if it was rubbing against the edge of the pulley.
But the electrical problem that im having is with the battery. When the ac compressor went bad it wouldnt spin anymore, and the belt broke the first time, both the ac and alternator belt are rotating together with that belt, so when it broke the alternator wasnt running anymore. So i was running off of battery for two days and my batter went out on me. at the same time, the battery fuse went bad as well. so i had to replace that, and i got a new battery, but my battery light in my dash keeps popping up and i dont know why. i got a new battery so what could it be?
Jun 4, 2009 at 8:03 AM
KHLOW2008
  • 41,812 POSTS
Hi slik6691,
Running the engine without the belt would fry the alternator rectifiers and voltage regulators if they were not disconnected. Guess you might have to replace the alternator as well.
Check for loose connections at alternator first and test the charging rate. Check fr blown fuses as well.
Jun 5, 2009 at 2:03 AM
