HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Prelude
Interior
Dashboard
Light
1992 Honda Prelude
JODIA
MEMBER
1992 HONDA PRELUDE
1992 Honda Prelude
what happen if when I turn on the car, the light on the dash board dont appear nor the engine dont stay on when I start it?
Sunday, April 12th, 2009 AT 9:38 AM
MECHANIC
Hi there,
This will be an electrical problem, check the main fuse efi fuse dash fuse check battery connection is clean & tight, start here.
Mark (mhpautos)
Sunday, April 12th, 2009 AT 10:12 AM
KHLOW2008
MECHANIC
Quite likely the ignition switch is faulty.
Car will crank and start but once key is returned to ON position, enine dies?
Tuesday, April 14th, 2009 AT 9:42 AM
Please
login
or
register
to post a reply.
Related Dashboard Light Content
1989 Honda Prelude Dash Lights
Electrical Problem 1989 Honda Prelude 4 Cyl Front Wheel Drive Manual 195k Miles I Was Recently Trying To Fix Some Of My Little Dash...
Asked by
scotty1990
1 ANSWER
1989
HONDA PRELUDE
94 Prelude Died While Running
I Have A 94 Prelude, With An H22 Swap (done 4 Years Ago) Its A 5 Speed, And Has Roughly 115k Miles On It. I Was Driving Around Town...
Asked by
ShoofIsLudin
1994
HONDA PRELUDE
1986 Honda Prelude Pgm-fi
Pgm-fi Dash Board Warning Light Is On. What Do I Have To Do. Also: Car Failed Smog Inspection. The Co Count Was To High. Was Told That The...
Asked by
dsoloist
1 ANSWER
1986
HONDA PRELUDE
1994 Honda Prelude Help!! Gas Pedal Is Stuck To The...
I Am Able To Start My Car, And Move Into Gear. However My Gas Pedal Has No Fuel Pressure When Pressed, And The Rpms Are Not Moving. Can...
Asked by
94prelude
1 ANSWER
1994
HONDA PRELUDE
1995 Honda Prelude Dash Display
I Have A 95 Prelude Si And For Some Reason, After Jumping It One Day A Thick Gray Smoke Came From The Dash For A Few Seconds And Ever Since...
Asked by
livestrongroadie
1 ANSWER
1995
HONDA PRELUDE
VIEW MORE
Instrument Cluster Replacement
Seat Switch Replacement
Airbag Removal - Drivers Side
