HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Prelude
Engine
Symptoms
Revs Up
1991 Honda Prelude When sitting idle
JKERR1957
MEMBER
1991 HONDA PRELUDE
4 CYL
2WD
MANUAL
149,000 MILES
When car is sitting idle engine goes up to 1600 rpm than back down to 1100 rpm over and over. What could be wrong with it?
Tuesday, August 17th, 2010 AT 7:41 PM
KHLOW2008
MECHANIC
Hi jkerr1957,
The idling system has a fault and it could be:
1, Vacumn leakages,
2. Faulty Fast Idle Thermo valve.
3. Lack of coolant.
4. Clogged coolant hoses.
5. Idling speed adjusted too high.
Saturday, August 21st, 2010 AT 7:27 AM
Please
login
or
register
to post a reply.
Related Engine Revs Up Content
1991 Honda Prelude Rattling Noise
I've Had This Problem For Some Time Now. I Can't Afford To Take It To A Mechanic Right Now. I Was Hoping I Could Get An Idea On Where The...
Asked by
syphonfilter77
1 ANSWER
1991
HONDA PRELUDE
GUIDE
Idle Air Control Motor Replacement
The idle air control motor or idle speed control motor is designed to adjust the air flow into the intake manifold at engine idle. Engine idle speed is monitored by the PCM...
1992 Honda Prelude Rpm Idling Issue
Engine - H22a With Jun Stage2 Cams Ecu - Piggyback With Unichip Recently My Rpm Drops Too Low, Abt 500rpm. It Usually Sits At 900rmp On...
Asked by
drian_pang
1992
HONDA PRELUDE
1997 Prelude Jerks When Rpm Reaches 3000
I Have A 5 Speed 1997 Honda Prelude Vtech Sh. The Car Runs Good Except It Will Not Go Past 60 Miles Per Hour Without The Car Jerking Really...
Asked by
brownb425
1997
HONDA PRELUDE
1989 Honda Prelude Engine Revs To High
When My Engine Is At Operating Temp. The Revs Are 1000. On Warm Up Revs At 1500rpm. Have Had New Head Rebuild Over 12months Ago. All...
Asked by
squiizy
1989
HONDA PRELUDE
2001 Honda Prelude Engine Rev's On Its Own
Hi, When My Car Is In Park It Will Rev On Its Own, Revs Up To Around 2500 Rpm Then Drops Suddenly To 1000rpm Then Goes Back Up. It Will Do...
Asked by
Furrion
2001
HONDA PRELUDE
VIEW MORE
Vacuum Leak Symptoms
Vacuum Leak Test and Repair
