1991 Honda Prelude timing/distributor problems
200,000 MILES • 4 CYL • FWD • MANUAL
ERIQARNES
I installed a new timing belt, and with the marks on the cam pulleys, and flywheel lined up, as well as having the #1 piston positioned at top dead center, the rotor does not line up with the #1 plug wire inside the distributor? Why, and what can I do to correct this?
Nov 17, 2009 at 5:33 AM
  • 75,988 POSTS
You're not on no.1 compression stroke/TDC
Nov 17, 2009 at 6:58 AM
