1991 Honda Prelude crank pulley
230,000 MILES • 4 CYL • 4WD • MANUAL
LUDER9178
looking underhood{deciding to tackle changing t-belt} the engine is at idle..and notice the crank pulley wobbling..check bolt{with belt on} and seemed nice and tight. I heard it was a 2 piece pulley. question 1 do i need to take belt off first to check how tight or loose it is? question2 can i fix it or do i need another pulley? b21a1 engine si 91 2.1 manual..thanks
Aug 6, 2008 at 6:02 AM
KHLOW2008
  • 41,812 POSTS
Hi luder9178,
The crankshaft pulley is defective so you need to replace it.
Aug 7, 2008 at 3:52 AM
