1991 Honda Prelude change dual carbs
251,003 MILES • 4 CYL • 4WD • AUTOMATIC
EHLIN
  • 30 POSTS
i have 2carbs in car the sensors valves and choke are not workingcan i cannot replace all this i suggest to install by one carb or can i to void valves or sensors whithout any problem........
thaaank u
Oct 3, 2009 at 6:07 AM
KHLOW2008
  • 41,812 POSTS
Hi ehlin,
What sensors are you refering to? What are not working?
To convert from dual to single carb, you would need to replace the intake manifold as well. Getting the part might be a problem as Preludes are either with dual carb or fuel injected.
Oct 10, 2009 at 1:56 AM
