1991 Honda Prelude Bad Drivetrain Wobble
165,000 MILES • 4 CYL • 2WD • MANUAL
PRELUDEBUILDER
motor/tranny seems to wobble between 25-45 accel and decel. noticed problem after i did some work, car also bottomed out repeatdly while driving due to lowered suspension around the same time. work done was timing belt, swapped a driver side fluid filled moter mount for an older model solid mount, and intake camshaft. trying to fix i have replaced worn out harmonic balancer, axles, intermediate axle shaft and swapped wheel/tire sets. have also exchanged old worn out cut suspension for coilovers. was told by gearbox transmission that it sounded like it was frame/alignment/suspension problem and that if it was transmission a noise would accompany or problem worsening rapidly, i have expoerienced neither. please help.
Mar 4, 2010 at 2:06 PM
KHLOW2008
  • 41,812 POSTS
Hi preludebuilder,
Check the axle shaft inner joints for wear and lac of lubricants. They would cause imbalance and vibration when accelerating.
Mar 7, 2010 at 6:05 AM
