1990 Honda Prelude engine timing
HALHALL
Engine Mechanical problem
1990 Honda Prelude 4 cyl Two Wheel Drive Automatic
if the timing belt breaks will the valvles get bent or will the head get damaged
Mar 28, 2009 at 1:33 PM
BMRFIXIT
  • 19,053 POSTS
Valves will get bent and head have to be removed for repair
Mar 28, 2009 at 1:41 PM
TED-E-DEE
  • 109 POSTS
Some motors are interference,{Valve damage will occur}, & some motors are Non-Interference,{Valves will not get damaged}. Call local Honda Dealer, give them your V.I.N. # & ask them if they could give you the info. . { Parts Department } is who you would want to talk to. My 88 Prelude is a interference motor, but the T-Belt broke at idle, I knew enough not to re-start "cause I suspected the belt & no damage occured. Thats luck !
Apr 22, 2009 at 12:48 PM
