1990 Honda Prelude Accelerating
PRELUDE1990
  • 1990 HONDA PRELUDE
  • 4 CYL
  • FWD
  • MANUAL
  • 171,000 MILES
When I push the throttle down halfway, the car bogs down and actually goes slower than when I let go of the throttle. If I push it all the way to the floor it starts to run as normal. If I turn the key off and on while I'm driving it'll fix the problem for a little while.
Wednesday, April 28th, 2010 AT 9:10 AM
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
Wednesday, April 28th, 2010 AT 5:05 PM
