1990 honda prelude
1990 HONDA PRELUDE
MEGS9609
I have a 1990 honda prelude 2.0 Si with 159,000mi. For the past year it has occasionally had trouble starting, but after a few tries it finally kicks over. Well today it didn't. I was told that the fuel pump finally gave out so I replaced it and the fuel filter. After everything was in place it still didn't start. Maybe it was just a bad pump or is there some kind of sensor that affect the pump?
May 1, 2007 at 8:05 AM
BRUCE HUNT
  • CAR REPAIR CONTRIBUTOR
  • 3,754 POSTS
After replacing the fuel pump can you determine if there is pressure at the rail where the injectors are located? If you have pressure, I would then look at the spark at a plug.
May 1, 2007 at 10:40 AM
