1989 Prelude fan switch/radio power loss
LMOEDER
  • 1989 HONDA PRELUDE
When this problem began, heater/ac fan and radio would not run when car first started but would start working while driving. Now they never work. Can not find any other compnents that don't work. Addition info: radio works in ACC key setting but not at full on. No change for fan switch. Fan switch does activate the radiator cooling fan if the AC button is punched but the cabin fan doesn't respond.
Wednesday, August 15th, 2007 AT 8:40 PM
2CARPRO JACK
  • 11,533 POSTS
Check for power at the fuse for the blower and radio when key is in run position. Check the fuses with a test light as well, key in run position
Thursday, August 16th, 2007 AT 7:40 AM
