1989 Honda Prelude pressure for clutch
133,000 MILES • 4 CYL • AWD • MANUAL
POVICKI
I had a clutch fluid leak in the interior of my car and replaced the master cylinder. I was still going through brake fluid and found that I had a leak in the clutch hydraulic pressure hose. I replaced that, but I cannot get any pressure to my clutch pedal. I cannot find any leaks and I am at my wits end. What could be the problem? Please help if you can.
Oct 3, 2009 at 4:42 PM
KHLOW2008
  • 41,812 POSTS
Hi povicki,
Did you manually pull the pedal up after every bleeding sequence? The pedal has an assist spring that will push the pedal to the floor if there is no back pressure.
Did you check if the slave cylinder is leaking?
Did you bench bleed the master cylinder?
Oct 10, 2009 at 1:59 AM
