1989 Honda Prelude hood realease
LAURITA1SIL
Other Category problem
1989 Honda Prelude Engine Size unknown Wheel Drive Type unknown Automatic 150.00 miles
I cant get my hood open. the latch on the inside is not working. is there any other way to open the hood from the outside without the latch release? the latch is broke from the inside. we tried to pull on the wire with pliers but it seems to be stuck or froze up. what can we try next?
Jan 17, 2008 at 1:05 AM
MIKE H R
  • 3,094 POSTS
what does the latch on the inside do? is it broken off from the wire or does the wire pull but not open the hood? If the wire does not pull then you can get it open by pulling on the wire. if the wire is loose then it is broken between the hood latch and the hood. Then you will have to get a hold of the cable under the hood to release it. Sometimes it is a pain trying to get at it.
Jan 17, 2008 at 2:18 AM
