1989 Honda Prelude fuses blowing
200,000 MILES • 4 CYL • FWD • MANUAL
CJALVES
my 89 prelude keeps blowing the fuse that controls the turn signals, tach and temp gage. i have replaced the fuse several times and it will work until i turn the car on and then it blows immeditly. i was curious if u knew what could be causing that.
Jul 24, 2008 at 1:36 PM
KHLOW2008
  • 41,812 POSTS
Hi cjalves,
You need to isolate all the components using this fuse and then try to figure out which is causing the shorting.
Did you do any bulb replacement or repairs prior to this happenening?
Aug 3, 2008 at 4:20 AM
