THE FUN NEVER ENDS WITH AN OLDER CAR...
1989 HONDA PRELUDE SI [4WHEEL STEER] [ONE OWNER CAR]
THE CAR HAS BEEN SITTING [LAST STARTED SAY 6 MONTHS AGO] I'VE PUT IN ADDITIONAL NEW FUEL.
TRIED TO START IT...NO LUCK. THE ONLY TIME I HAVE EVEWR NOT BEEN ABLE TO GET THE CAR STARTED IS WHEN THE FUEL PUMP WENT OUT...SO, I CHECKED THE "ALTERNATOR / FUEL PUMP" 10 AMP FUSE...BURNED OUT...TRIED A REPLACEMENT ... SAME RESULT.
IS THE PROBLEM WITH THE FUEL PUMP [A SHORT OF SOME KIND] OR WITH THE ALTERNATOR?
THANK YOU...
THANK YOU...
Mar 17, 2009 at 1:40 PM
