1989 Honda Prelude CLUTCH MASTER CYLINDER OR SLAVE CYLINDER
100,000 MILES • 4 CYL • 2WD • MANUAL
WALLY5
I PUSH THE CLUTCH PEDAL IN AND IT STAYED ON THE FLOOR CHECKED THE FLUID LEVEL (LOW). THERE IS NO APPARENT SIGN OF A FLUID LEAK ( NOT AT MASTER CYLINDER OR THE SLAVE ) HOW DO I TELL WHICH ONE IS FAILING ? THIS CONDITION HAPEND TWICE IN A FEW DAYS. I ADDED FLUID AND BLED THE SYSTEM IN BETWEEN FAILINGS AND BROUGHT THE SYSTEM BACK.
Jan 30, 2008 at 9:44 AM
  • 75,988 POSTS
Either you get a rebuild kit or replace the clutch master cylinder.
Feb 2, 2008 at 6:45 AM
