1989 Honda Prelude check engine warning light
189,000 MILES • 4 CYL • FWD • AUTOMATIC
STILLWORKIN
The check engine light is on and the engine is not running as it should.
The owners book states that this light indicates a problem with the fuel injection.
Is there a sensor that needs replacing or is this more serious and may require injection overhaul.
The light started to come on intermittently but is now on all the time.
Engine is now slower to start.
Jun 11, 2008 at 12:03 AM
  • 31,937 POSTS
Hi there,
There are a number of components that can be at fault. If you run a scan and retrieve the code, it will indicate the item that has set the fault so you or your tech will know where to start looking.
mark (mhpautos)
Jun 11, 2008 at 12:17 AM
