HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Honda
Prelude
Engine
Symptoms
Not Cranking Over
SPONSORED LINKS
1989 Honda Prelude
BEVCOL
MEMBER
1989 HONDA PRELUDE
Engine Performance problem
1989 Honda Prelude 4 cyl Automatic
Car won't crank
Wednesday, March 31st, 2010 AT 5:29 PM
KHLOW2008
MECHANIC
Hi bevcol,
Did you check the battery?
If jumpstarting works, the battery could be bad or drained.
SPONSORED LINKS
Saturday, April 10th, 2010 AT 10:58 PM
BEVCOL
MEMBER
Yes, we checked the battery.
Wednesday, April 14th, 2010 AT 1:56 AM
KHLOW2008
MECHANIC
Does jumpstarting works? If not, it could be the starter or ignition switch.
Disconnect the starter solenoid wire and attach a remote wire to apply voltage. If starter does not crank, it is faulty.
Wednesday, April 14th, 2010 AT 6:07 AM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
1989 Honda Prelude Cranks Over But Won't Start After...
I Drive The Car Somewhere, Park And Leave It Usually In Hot Weather. I Come Back And The Car Will Crank Over But Not Start. Plenty Of Fuel...
Asked by
gaffeli
1 ANSWER
1989
HONDA PRELUDE
GUIDE
Starter Not Working
This guide is designed to help you identify whether the issue with your non-working starter motor is due to an electrical problem or a fault within the starter motor itself...
1996 Honda Prelude 96 Honda Prelude Srv Turns Over...
I Have A 1996 Honda Prelude Srv. Approximately 2 Months Ago I Had The Timing Belt Replaced. At That Time The Crank Sensor Was Also Changed...
Asked by
96 prelude SRV
1996
HONDA PRELUDE
1992 Honda Prelude Wont Crank By Hand
Transmission Problem 1992 Honda Prelude 4 Cyl Front Wheel Drive Automatic I Have A 1992 Prelude Type S With A !994 Honda Accord F22b2...
Asked by
sidestudios
1992
HONDA PRELUDE
No Crank
I Am Having Problem With My Honda Prelude 1998. When I Park My Car Under Sun It Gets Heat Up And Doesnt Crank At All, Then I Have To Park...
Asked by
shahjee
1 ANSWER
1998
HONDA PRELUDE
Car Won't Crank
I Have A 1993 Honda Prelude 1.8 Engine, 150,000 Miles, Recently After Driving The Car I Noticed That The Brake Lights Remained On After I...
Asked by
reggieo
1 ANSWER
HONDA PRELUDE
VIEW MORE
SPONSORED LINKS
Battery Replacement Video
Starter Motor Replacement
Battery Replacement Toyota
Online car repair manuals
