1988 Honda Prelude Loose Clutch
10,300 MILES • 4 CYL • FWD • MANUAL
LRUDY54
A couple weeks after a 500 mile trip, I got in the Prelude and noticed the gears were hard to shift. Didn't think much of it until I got in yesterday to take a drive and the clutch had very little tension in it and when I started the car it was hard to change the gears. Naturally, I changed my mind about the dirve for fear of tearing something up.
Since I can get the gears to change with the car off, I pulled it out of the garage to check under the hood and to see if I could see any spots from a possible leak.
I did not see any signs of leakage, but when I check the clutch fluid, I noticed it seems low. The fluid only comes to the top of the tube, there is none in the resevoir....it is below the min line.
I realize it probably needs fluid. Am I correct when I say brake fluid instead of transmission fluid? I think DOT 3. Will any brand do or do I need to get Honda brand?
If this doesn't fix the problem, would it hurt to drive it to the dealer for evaluation? I don't want to strip any gears or cause damage to the transmission if the problem is in the clutch.
Also, how do I know if the line needs to be bled?
Thank you,
Linda R.[img:c80b4a6dcd]http://www.2carpros.com/forum/automotive_pictures/229303_Prelude_With_Wheels_005_1.jpg[/img:c80b4a6dcd]
[img:c80b4a6dcd]http://www.2carpros.com/forum/automotive_pictures/229303_Prelude_With_Wheels_011_1.jpg[/img:c80b4a6dcd]
[img:c80b4a6dcd]http://www.2carpros.com/forum/automotive_pictures/229303_Prelude_With_Wheels_004_2.jpg[/img:c80b4a6dcd]
[img:c80b4a6dcd]http://www.2carpros.com/forum/automotive_pictures/229303_PreludeWithWheels015_1.jpg[/img:c80b4a6dcd]
Aug 17, 2008 at 7:05 AM
KHLOW2008
  • 41,812 POSTS
Hi lrudy54,
Use DOT 3 or 4 brake fluid to top up. I don't believe there is any Honda brake fluid.
There should be a leakage somewhere and it could be the master or slave cylinder.
Bleeding would be required if the fluid ha leaked dry from the master cylinder. Sometimes operating the clutch pedal would get the clutch back.
Aug 23, 2008 at 3:06 AM
