1988 Honda Prelude Idle speed
13,000 MILES • 4 CYL • FWD • MANUAL
HOCKEYDUDE515
i have a question for you about the idle speed of my car. It actually has to do with when u start it. When started, it runs hits 2,000 rpms and keeps rising until it is at an upwards of 3,200 or more and then in about 5 min. or less it will slowly decrease and then go to a very low idle so it sounds as if it will quit. A good friend and car fanatic told me that i should check out the vacuum with a meter to check if there is a leak because that can cause the problem. i was wondering what you input on this subject was if he was correct and what u believe the problem could be.
P.S. do i need to use a credit car to donate money?
Aug 10, 2008 at 11:56 AM
KHLOW2008
  • 41,812 POSTS
Hi hockeydude515,
Your friend is correct up to a certain extent.
The cold start valve (Fast Idle Valve) is faulty/incorrectly adjusted/opened too much resulting in the extremely high rpm, 3,200. (Vacumn leakage)
When the engine seems like stalling after warming up, insufficient amount of air is getting into the intake manifold. This is due to clogging of air passages.
I would recommend checking EACV, throttle body and their coolant hoses for clogging.
Donations can be made with credit card or Paypal.
Aug 16, 2008 at 5:27 AM
