1986 Honda Prelude will crank but wont start
160,000 MILES • 4 CYL • FWD • MANUAL
DARKPILLER3200
  • 11 POSTS
will crank over but wont start have checked fuel pump and spark is good i smell alot of fuel from exaust pipe when cranking have checked timming belt and timing any ideas out there i am stumped
Sep 19, 2008 at 8:23 PM
  • 75,988 POSTS
Spark, Fuel and timing are good -check whether the choke plate is opening up if not it'll dump a lot of fuel and cause it to flood out.
Sep 19, 2008 at 8:37 PM
DARKPILLER3200
  • 11 POSTS
I have done that seems to work fine not sure what else it could be
Sep 19, 2008 at 9:17 PM
  • 75,988 POSTS
Check the actual fuel pressure could be excessive due to a defective pressure regulator
Sep 19, 2008 at 9:19 PM
DARKPILLER3200
  • 11 POSTS
where can that be located or what dose it look like
Sep 19, 2008 at 9:28 PM
  • 75,988 POSTS
Is this a throttle body injection-which people at times think of it as carbuerator or it is an actual a carb or a multi point injection.
Pressure reguialtor are mounted within the ends of the fuel rail a little canister looking with a vacuum hose on it
Sep 19, 2008 at 9:33 PM
DARKPILLER3200
  • 11 POSTS
ok i have found it has a gas line from the underside and a vac line from the top how can i test it and or what would you think the cost to replace would be
Sep 19, 2008 at 9:38 PM
  • 75,988 POSTS
Remove the vacuum hose and inspect for fuel in it or the regulator side if present its a goner.
The color of the spark is orange or blue?
Sep 19, 2008 at 9:42 PM
DARKPILLER3200
  • 11 POSTS
the spark was blue and i looked at the vac line seems to be dry and all around it is dry as well there is another device close by there that looks alot like it and has a screw with sping on it do you know what that might be looks like some kind of an ajustment
Sep 19, 2008 at 9:50 PM
  • 75,988 POSTS
How did you check the timing? I need to know this before we can continue
Sep 19, 2008 at 9:53 PM
DARKPILLER3200
  • 11 POSTS
by timeing marks the car was runing till about a week ago when i pulled out of my driveway and it died and wont start anymore have checked fuses
Sep 19, 2008 at 9:55 PM
  • 75,988 POSTS
Open up the distributor cap have helper crank engine over while you check whether the rotor is turning.
Did you do a static or dynamic with a timing light
Sep 19, 2008 at 9:57 PM
DARKPILLER3200
  • 11 POSTS
i have never done that not sure how to do it have always timed by marks will have to check dist cap in morning when i have a helper to turn it over
Sep 19, 2008 at 10:00 PM
DARKPILLER3200
  • 11 POSTS
wouldnt the dist move in order to make the plugs spark i could be wrong
Sep 19, 2008 at 10:02 PM
  • 75,988 POSTS
Put the engine on TDC line the markings oon the damper TDC/0 make sure your not on the exhaust stroke otherwise you gonna be 180deg off-where is the rotor point at is it no.1 or no4?
Sep 19, 2008 at 10:07 PM
DARKPILLER3200
  • 11 POSTS
It is on the #1
Sep 19, 2008 at 10:12 PM
  • 75,988 POSTS
Did you had anything to do with the timing belt before it refuses to start?
Sep 19, 2008 at 10:15 PM
DARKPILLER3200
  • 11 POSTS
nope the car ran great then died and wouldnt restart the battery was tested also i am very stumped
Sep 19, 2008 at 10:17 PM
  • 75,988 POSTS
Okay Buddy -Let me ask again does it crank over and refuses to start or just won't crank over at all.
Sep 19, 2008 at 10:23 PM
DARKPILLER3200
  • 11 POSTS
it cranks over fine just wont start
sorry if i am bugging you if you dont want to help its fine just let me know thanks for help thus far
Sep 19, 2008 at 10:25 PM
  • 75,988 POSTS
You're not bugging me my job here is to help you out-I'd have done that earlier if it is-
Do below and tell me what happened
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil,distributor pick-up coil, ignition control module, cam and crank sensors-
Sep 19, 2008 at 10:30 PM
  • 75,988 POSTS
In the event your getting spark and fuel is reaching the plugs-try to reset the the valve timing by putting engine no.1 piston on compression stroke/TDC then line the sprockets as you see below
https://images.2carpros.com/forum/automotive_pictures/12900_cam86_1.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_crank1_2.jpg
https://images.2carpros.com/forum/automotive_pictures/12900_crank2_1.jpg
Sep 19, 2008 at 10:41 PM
