1985 Honda Prelude Honda can't hold power to run
CATLINGAL
  • 1985 HONDA PRELUDE
Electrical problem
1985 Honda Prelude 4 cyl Front Wheel Drive Manual
1985 Honda Prelude Died As If It Had A Drained Battery. But, After Buying A New Battery, Changing Out The Alternator And A New Voltage Regulator, We Are Still Experiencing A Drain On The Battery. Its A New Battery And Once It Starts It Shows A 11.6 But After Its Been Running We Are Only Getting 10 Volts. Then After Its Been Running About 3 To 5 Minutes It Dies Because It Has No Power. What Could Be Causing This?
Wednesday, May 13th, 2009 AT 2:17 PM
KHLOW2008
  • 41,814 POSTS
Hi catlingal,
The charging sysem is faulty and not providing sufficient charge to the battery.
Is alternator equipped with IC regulator or does it has a separate voltage rtegulator?
Did you test the charging voltage at the alternator main terminal?
Does the charge indicator light shows?
Friday, May 22nd, 2009 AT 12:13 PM
