1982 Honda Prelude Starter removal
153,000 MILES • 4 CYL • FWD • AUTOMATIC
82LUDE
I am removing the starter from my 82 prelude. I removed the top bolt but I think the bottom bolt is cracked off or stuck. I can pull the starter out of its housing from the top but the bottom will not move. Is there a way to remove the starter without cutting it
Jun 19, 2010 at 4:21 PM
KHLOW2008
  • 41,812 POSTS
Hi 82lude,
Some of the earlier models have the lower bolt with a nut at the other end. If that is the case, you would need to remove the nut from behind the engine block to enable the starter to be removed.
Jun 23, 2010 at 7:58 AM
