2003 Honda Pilot Brake Squeak
MARCOPILOT
I have a 2003 Honda Pilot awd with the 3.5l v6. It has 51,000 on it. I recently had the brakes done and about 2,000 now it has started to make a intermittant low pitched squeeking noise when I stop. It sounds similar to the sound a wheel makes if the lugs are loose. I checked that first but they are all tight. the sound is very faint until I have driven and the car warms up and gets progressively louder. If i slow down without braking, using the transmission the sound is not there.
Jun 9, 2007 at 3:16 AM
BRUCE HUNT
  • 3,754 POSTS
Are you stating that the brakes were done about 2000 miles ago or it cost you $2000? The noise you hear as you have determined is brake related. I don't know whether you installed the brakes or not but I ask to whether they only make the noise in forward or does it also do it in reverse?
There is a small metal indicator on the brakes that tells when they are in need of replacement. I would check the brakes again to see that is wasn't bent forward and is touching the rotor. Could be one wheel. I am assuming that you did a complete brake replacement front and back, right?
Jun 11, 2007 at 2:26 AM
Suggested Repair
Recheck the brakes, especially the metal wear indicators, for a tab bent into contact with a rotor. Confirm whether the squeak occurs only going forward or also in reverse, and inspect all wheels if a full front-and-rear brake job was done.
Conversation Summary
A 2003 Honda Pilot with 51,000 miles developed an intermittent low-pitched squeak when stopping about 2,000 miles after a brake job. The noise grows louder as the vehicle warms up and does not occur when slowing with the transmission. Lug nuts were confirmed tight. The expert said the noise is brake-related and recommended checking whether a wear indicator is bent and touching a rotor, possibly at one wheel.
