piolt ac
HONDA PILOT
JEFF3232
i have a 2004 pilt the front ac is not working the fan is not blowing and it sounds like the compresser is not working i checked all fuses they are good the rear ac blows but is not cold is there a fuse othe than the ones on driverside and under the hood thanks j
Oct 27, 2007 at 1:20 AM
2CARPRO JACK
  • 11,533 POSTS
First start the engine and turn on th ea/c, look underhood to see if the a/c clutch on the compressor is engaging (the center plate will spin if it is engaged). If not engaging have the freon pressures checked, could be a little low. The blower fan.. get a test light and see if you have power at the blower motor.If not follow wires back to the fan speed resistor and verify power into it. Get back to us
Oct 27, 2007 at 1:52 AM
