2006 Honda Pilot Transmission and Transfer Fluid Change
2006 HONDA PILOT
40,000 MILES • 6 CYL • 4WD • AUTOMATIC
KUMERCA
I am getting in Maintanence Minder code 3, which is to replace transmission and transfer fluid.
I have changed the transmission oil using the honda approved ATF-Z1.
How do I change the transfer fluid or is is the same as changing the transmission fluid. I can not find any answers in the owner manual nor online.
thanks for your help.
Jan 1, 2009 at 1:26 AM
HONDATECH74
  • 34 POSTS
[quote:99d1b4bc25="kumerca"]Transmission problem
2006 Honda Pilot 6 cyl Four Wheel Drive Automatic 40000 miles
thanks for your help.[/quote:99d1b4bc25]
there is a drain and a fill on the transfer case much like the differential. The fluid used is not the same as the transmission fluid.
Feb 27, 2009 at 9:03 PM
