2005 Honda Pilot floor boards wet
45,000 MILES • 6 CYL • AWD • AUTOMATIC
JOE301
the front carpet gets wet after a rain,,,, is there a drain
tube for the sunroof,,,,??? if so how do you clean it out?
joe
Oct 28, 2009 at 8:00 AM
HONDA TECH 1818
  • 536 POSTS
The sunroof drain tubes are located in the front kick panels. You need to remove the kick panels and locate the the drain tubes, you can pour water in the sunroof front drain holes to see if the water drains throught the tube and make sure they are coonected to outside of the body. Or you could pull the front carpet out to check for water leaks. Just have someone outside spray water with a hose and check where the water is coming from. I seen couple of Pilots leaking from the front body seam.
Nov 12, 2009 at 6:45 PM
