2005 Honda Pilot brake lights not working
65,000 MILES • 6 CYL • AWD • AUTOMATIC
FISHPONDZ
We have a 2005 Pilot and ALL the brake lights are out. The tail lights work, and all the lights flash (except the one brake light on the very top) as they should when we set the alarm. So the bulbs are fine. The fuse looked fine but we replaced it anyway. My husband replaced the brake light switch, and still nothing. The rear power outlet is also out, but I'm not sure if they went out at the same time. Any ideas on what to try next??
Nov 19, 2008 at 10:46 AM
BMRFIXIT
  • 19,053 POSTS
If its the 3rd light
switch was replaced and the bulbs
you have to check for power and check for ground at the socket
check wiring
Jan 17, 2009 at 5:38 AM
