2004 Honda Pilot Rear bearing replacement
157,000 MILES • 6 CYL • 4WD • AUTOMATIC
JEFFRIDFORD
What is the procedure for replacing the rear bearings on this vehicle? When buying the replacement parts the bearings come in groups of 2. Do both sides need to be replaced? Are any special tools needed? The bearings don't need to be pressed out do they?
Thanks,
Jeff Ford
Oct 25, 2010 at 1:34 AM
KHLOW2008
  • 41,812 POSTS
Hi Jeff Ford,
Thank you for the donation.
The file is too large to be posted here so I have emailed it to you.
For wheel bearings replacement, they are done as and when necessary therefore it is not necessary to replace both at the same time unless both are bad.
Yes, the bearings have to be pressed in and out.
Oct 25, 2010 at 2:02 AM
