2004 Honda Pilot jerky, stops pulling, shut engine down and
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
JTR32533
This just happened this week. Wifes honda pilot transmission starts jerking and will quit pulling on street use only, never offroad. shut engine off and start back up and it runs fine a while 15 minutes or so. Tried to trigger some sort of light combination blinking, using engine off while in gear then shift back to park and restart, plus other combinations. found one combination with the shifter in first, the drive light would blink. not sure what I was doing when I got it to do that. Never had transmission trouble before. Always dealer maintained on schedule.
Jul 31, 2009 at 5:19 PM
KHLOW2008
  • 41,812 POSTS
Hi jtr32533,
Thank you for the donation.
When the D4 light blinks, an error has been detected in the transmission control system and a scan is required to retrieve the trouble code for diagnostics and rectification.
Get the scan done and let me know the trouble code so I can assist in diagnosing the problem.
Aug 1, 2009 at 2:59 AM
