2004 Honda Pilot air cabin filter
78,000 MILES • 6 CYL • FWD • AUTOMATIC
MARCUS111
Can you help me identify the location of my cabin filter in my 2004 Honda Pilot. It does not appear to be located behind the glove box. Thanks, Marcus
Mar 17, 2010 at 12:50 PM
  • 75,988 POSTS
Heating And Air Conditioning Component Location Index
https://images.2carpros.com/forum/automotive_pictures/12900_cf_2.jpg
Dust and Pollen Filter Replacement The dust and pollen filter should be replaced every 30,000 miles (48,000 km) or 24 months whichever comes first Replace the filter more often if the airflow is less than usual 1.Remove the glove box.
https://images.2carpros.com/forum/automotive_pictures/12900_caf_3.gif
2.Cut the plastic cross brace in the glove box opening with diagonal cutters in the area shown, and discard it.
https://images.2carpros.com/forum/automotive_pictures/12900_caf2_2.gif
3.Remove the bolts, the screws and the glove box frame.
https://images.2carpros.com/forum/automotive_pictures/12900_caf3_2.gif
4.Remove the filter lid (A) from the evaporator, then pull out the dust and pollen filter (B) Note the direction of the arrow. 5.Install the filter in the reverse order of removal Note the direction of the arrow Make sure that there is no air leaking out of the evaporator Note the direction of the arrow. 6.Install the glove box frame and glove box in the reverse order of removal. https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
Mar 17, 2010 at 2:26 PM
