2003 Honda Pilot Transmission
102,000 MILES • 6 CYL • AWD • AUTOMATIC
DGSOC
I am also hearing a winding sound coming from the engine compartment at different speeds. Has anyone experinced this?
Jan 20, 2010 at 1:19 PM
  • 31,937 POSTS
Hi there,
This may well be a failing pulley bearing, a good mechanic should be able to pin point which is causing your problem, also just check the belts for condition & tension, start here.
mark (mhpautos)
Jan 20, 2010 at 1:31 PM
