I am also hearing a winding sound coming from the engine compartment at different speeds. Has anyone experinced this?
Jan 20, 2010 at 1:19 PM
✓Experienced Mechanic
Hi there,
This may well be a failing pulley bearing, a good mechanic should be able to pin point which is causing your problem, also just check the belts for condition & tension, start here.
