My 2003 Honda pilot is slipping on occasion when I push on the gas pedal. Is this a transmission problem and what is the first step I should take?
Aug 6, 2010 at 5:54 PM
KHLOW2008
✓Experienced Mechanic
Hi Safiregod,
First thing you should do is check the fluid level and condition.
How bad is the slipping or it it just the trans downshifting?
Aug 6, 2010 at 11:38 PM
SAFIREGOD
MEMBER
thank you i will check the level and condition of the fluid. the slipping happens on occasion when i push on the gas pedal, then it takes a second or two to catch up. it doesn't happen that often. so i dont know how bad it is or isn't.
Aug 8, 2010 at 4:43 AM
KHLOW2008
Symptoms indicates the fluid level is possibly low. If not then the trans could be failing.
