2003 Honda Pilot CV Joint
2003 HONDA PILOT
56,000 MILES • 6 CYL • 4WD • AUTOMATIC
BIGPAPA4332
When accelerating, even slightly, with the wheels turned there is a grinding sound coming from the right front - the sound goes away as soon as you take your foot off the accelerator (even with the car still moving) or when you strighten the car out. The grinding sound is most pronounced when making a sharp turn pulling out of the garage. I've had the dealer and several shops address this problem with no results. I'm inclinded to think its a CV joint issue but there is no indication of a tear in the boot and its not a clicking or popping sound.
Jul 1, 2008 at 4:50 AM
KHLOW2008
  • 41,814 POSTS
Hi bigpapa4332,
Is this vehicle equipped with a separate differential for the front? If yes, I would suggest replacing the differential fluid.
I do not think it is the CV joints. A faulty engine mount or something getting between it would be more likely.
Jul 8, 2008 at 9:19 PM
