Horrible, horrible honda (passport)
JONNYP50
2000 Honda Passport 4wd w/ 75k mi first did not want to crank, then would turn over but would not crank. Took to local mechanic--they replaced a sensor. Car cranked for a day or two, died again. Went back to local mechanic; they towed it to dealership. Service dept. claimed it cranked, first time, every time, though they kept it 2 weeks. Retrieved car, had a little trouble cranking it, but after a week, drove it home from Troy (about 60 miles). Car died. No cranking, would not even turn over. Replaced fuel pump. Still dead.
May 21, 2007 at 6:18 AM
BRUCE HUNT
  • 3,754 POSTS
You use the word crank freely. Crank means to me the engine turns over. I assume that you have checked to see if the fuel pressure is correct and constant. Have you checked the spark of the vehicle as well?
May 24, 2007 at 1:35 AM
