95 Honda Passport LX 3.2L 6-cy 101,000 mi
BOOYA8
i replaced alternator belt and p/s oil pump belt but left off a/c compressor belt but when i start car, engine makes loud metallic sound and crank pulley is loose and wobles. what do i do?
Jan 22, 2007 at 10:11 AM
MATHIASO
  • 1,209 POSTS
do you have a picture of the "crank pulley "
that may be the noise you are hearing.
Jan 22, 2007 at 3:38 PM
2CARPRO JACK
  • 11,533 POSTS
Inspect it to see if the rubber ring has come apart or if it is just loose. I wouldnt drive it until the problem is fixed, If the balancer comes off at speed it will do alot of damage to the other accesories
Jan 22, 2007 at 11:44 PM
