My rear drums will not come off no matter what i try?
2001 HONDA PASSPORT
192,000 MILES • 6 CYL • 2WD • AUTOMATIC
PAT.KAY.
My rear drums will not come off no matter what i try, is there a certain way to get the drum off to change the pads or could it be rusted that bad?
Sep 21, 2010 at 6:08 PM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi pat.kay.,
Sometimes the drum is stuck and you need to spray some rust remover onto the ring at center of hub and bang with a hammer to loosen it.
This video can help
https://youtu.be/UV0kfP17Co0
sometimes you need to loosen the adjusters turn the adjuster up or down to loosen depenidn gon which side you are on.
There are 2 threaded holes that you can insert 2 pcs of M8 bolts to act as puller to get the drum off. Ensure the handbrake is released before doing so.
Oct 3, 2010 at 10:34 AM
