2000 Honda Passport What's Wrong?!
MELYMEL
124,000 miles. I have replaced the transmission, the fuel pump, the mass air flow sensor, fuel filer, alternator, battery, and a tune up. The car still doesn't want to work. It shuts off while I am driving down the road. Does this sound like an electrical issue?
I have put over $4,000 in repairs over the last 2 years.
Oct 11, 2007 at 2:28 PM
FISHERMAN
  • 937 POSTS
[quote:fed58754aa="melymel"]124,000 miles. I have replaced the transmission, the fuel pump, the mass air flow sensor, fuel filer, alternator, battery, and a tune up. The car still doesn't want to work. It shuts off while I am driving down the road. Does this sound like an electrical issue?
I have put over $4,000 in repairs over the last 2 years.[/quote:fed58754aa]
Hello !!
Well,
Did you check the fuel pump for correct pressure after replacing?
check the ignition switch.. some hondas have problems with it..
the fuel pump relay and the Main relay....
Have that check also....
Check this out:
http://corporate.honda.com/press/article.aspx?id=2002052353859
It start right away or do you have hard time to start it over?
Let us Know !!
Oct 11, 2007 at 3:41 PM
