I have a vacuum leak at the rear of the engine, it is so bad that the truck won't idle and pops back through the intake when rpms are run up, I replaced the small line to the evap solinod but still have a leak. I can't see any other lines, but when I spray silicon at the rear of the manifold the engine revs up and runs good. Is ther another line back there? do I have to remove the penlum to get to it? Could it be the throttle shaft? any help would be great!
p.s 8in vacuum at idle
Brian
Brian
Mar 16, 2010 at 1:10 PM
