starter
100,000 MILES • 6 CYL • 4WD • AUTOMATIC
LAG4BRKE
want to know what i have to take off to get starter out or if there is enough clearance to pull it out towards the back trans way also mitchell online, one yr is 30, can you change vehicles or is it 30 per vehicle to use there service.
Jan 22, 2009 at 7:13 PM
KHLOW2008
  • 41,812 POSTS
Hi lag4brke,
Removal & Installation
1. Disconnect battery ground cable. Lift and support vehicle above ground. Disconnect 2 heated oxygen sensor connectors from left front exhaust pipe.
2. Remove left front exhaust pipe with catalytic converter to access starter. Remove starter heat shield and connectors. Remove starter bolts and drop starter toward bottom of engine.
3. To install, reverse removal procedure. Tighten starter and exhaust bolts to specifications.
© 2008 Mitchell Repair Information Co., LLC.
As to the question on Mitchell1, I do not know the answer and will check with the admins. You might have to write to Mitchell1.
Jan 31, 2009 at 6:09 AM
THIS IS MIKE
  • 686 POSTS
The Mitchell1 subscription is for a single vehicle only.
Jan 31, 2009 at 9:08 AM
SAMUEL M HOUSTON
Well you can spen time trying to break lose the manafold to exhaust pipe bolts qty (3x 17 mm socket size) and take a chance at breaking the manafold on your 200k+ mile passport may work. Some people have had success removing the moter to frame mount ( hard to get to 14mm head bolts will take a wobble socket and a couple of long extensions from under the hood... What we do at the ranch were we buy these vehicals cheap and use them until they are worn out unbolt the starter and twist it around the cavity that its in an un bolt/clip and push it out of the way and take a sawzall and cut the shroud and thermal braket off of the transmission housing this will still allow you to reninstal the thermal sheilding with only one bolt instead of two. Cutting the transmission housing will allow you to change starters freely with out removing anything else
Apr 21, 2019 at 4:05 PM
  • 55,594 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Apr 22, 2019 at 8:40 AM
2CP-ARCHIVES
  • 4,540 POSTS
just replaced starter and steering colomn. after the starter was replaced,i had to push up on the wheel to align and turn the key to get it to start now ,when turn key the starter wont respond
Apr 22, 2019 at 8:40 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
Depending on what position the wheels are in sometimes you have to turn the steering wheel to unlock the ignition.So why did you replace the starter to began with?Does the starter make any noise while trying to start it now?
SATURNTECH9
  • 30,869 POSTS
Also do you have a multi meter to do some testing?
MOMJULLY
When I turn the key to start the car, sometimes it turns over just fine, but other times it just makes a clicking sound and doesn't turn over. Batter is just fine, checked all fuses, I have concluded that the problem is the starter. I do not have the $$$ to pay to have starter replaced. how do I replace myself?
KHLOW2008
  • 41,812 POSTS
Check out above link for more information.
5TH LETTER
  • 10 POSTS
I am trying to remove the starter on my 2000 Honda Passport and I don't know where it is. Any help would be appreciated.
KHLOW2008
  • 41,812 POSTS
Hi 5th Letter,
Simple procedure is to follow the battery positive terminal cable to where it ends.
5TH LETTER
  • 10 POSTS
[quote:ace5dd4c21="KHLow2008"]Hi 5th Letter,
Simple procedure is to follow the battery positive terminal cable to where it ends.[/quote:ace5dd4c21]
Much appreciated.
MARES23
I need help finding the starter on my car ...I dont know where it is at..please help
SERVICE WRITER
  • 9,123 POSTS
Lower left side of the engine if it is the 3.2 motor and the lower right if it is the 2.5 motor.
