2000 Honda PAssport stalls on turns
DAVEINSIERRAS
  • 6 POSTS
I have a 2000 Honda Passport EX 3.2L V6 w/auto trans 4x4 97,000 miles. On occassion when going around corners or coming to a quick stop the car will stall out. It starts right back up most of the time but sometimes the idle will be real low and I have to put on the air conditioner to bump up the idle so I can accelerate without it stalling again. From your forums on stalling it sounds like a faulty idle control valve. However I cannot find one on this vehicle and the parts stores only list an idle control valve on 1999 and earlier models. I have previuosly replaced the EGR valve and the throttle position sensor. What do you think?
Jul 4, 2007 at 2:42 AM
2CARPRO JACK
  • 11,533 POSTS
Might not have an IAC valve, does it have a throttle cable? drive by wire vehicles usually dont have them. try removing the air intake boot and having someone hold the throttle wide open while you clean out around the butterfly with some carb spray and a rag, that might help stabilize the idle, if too much reversion has built up around it
Jul 6, 2007 at 1:07 AM
